I have had a huge problem with my 2000 S80 radiator boiling over. I changed thermostat, checked water pump and realized the cooling fan is not coming on. I've been driving with the heat cranked up and the heater fan on. I replaced the fan twice. The first time, it would not go off. Now the replacement won't come on. I checked the resistance of what I believe is from the temperature sensor going to the fan for I assume is the signal to turn on the fan. The resistance when hot is 167k ohms. Sounds high to me. It has a purple wire.
Is this the cause?
Cooling fan not coming on
- 12 Replies
- 2300 Views
Last post by subzerocarfanatic
- 1469 Views
Last post by chrism
- 22 Replies
- 7557 Views
Last post by sleddriver
- 783 Views
Last post by Vovo_merz
- 1580 Views
Last post by Py
