1993 850 RPM pulsing up and down at idle Topic is solved
Paul-93-850
Year and Model: 1993 850 non-turbo
Post by Paul-93-850 »
1993 850
Check engine light came on and code indicated the MAF.
RPMs were very high at idle.
I bought a re-manufactured Bosch MAF and now the RPMs pulse up and down at idle.
What might this indicate?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Is your check engine light still on? When was the last time your IACV was cleaned?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Paul-93-850 wrote: 04 Oct 2017, 12:58 ...I bought a re-manufactured Bosch MAF and now the RPMs pulse up and down at idle.
That indicates that re-manufactured & aftermarket MAF will not work on these cars.
Only brand new or even good known used OEM BOSCH.
1993 n/a should use just an insert.
Disconnect the MAF and see if it runs better.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Paul-93-850
Disconnected the MAF and it idles too fast.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
But it doesn't surge? Bingo - the MAF is the problem.
Remanufactured MAF will have non-Bosch electronics, and they usually (like 90% + of the time) don't work right in these cars.
misha
Post by misha »
Fast idle with maf disconnected could indicate a clogged iac valve or a vacuum leak.
The fact that fluctuating up & down rpm goes away with maf disconnected indicates that maf is bad.
NEVER use aftermarket sensors on these cars.ONLY oem....new or good known used.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
Somehow my post has been duplicated.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Paul-93-850
I removed and cleaned the idle air control and the throttle body. No apparent bad vacuum hoses. High idle speed has only dropped slightly. Still rough and hesitating acceleration. When first starting, the idle goes up and down a few times and then stays high.
Before doing the cleaning the code only showed 1-1-3 short term fuel trim upper limit.
Assuming MAF is OK, what would these symptoms indicate?
misha
Post by misha »
Re-manufactured or aftermarket Maf CAN'T be ok for these cars.
It's better to run the car with it disconnected.
Other that...large vacuum leak somewhere like ribbed plastic hose from air filter housing,vacuum tree,pcv system,hose for fuel evaporation...
On how much rpm it is idling?
N/a idles around 900(+-50) rpm.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Paul-93-850
RPM at idle goes from around 1200 to 1800.
