Hello, from couple of months i have a problem with ECC damper motors, the air comes only from the front, when i switch to floor or defrost nothing happen, Temp adjustment and fan speed works good
There is two error codes 2-3-1 and 2-3-3.
All damper motors working when i plug them to 9v battery.
I've replaced blower resistor whole electric bundle from control panel to damper motors, interior temp sensor e.t.c. tried 4 different control panels and nothing has change...
Maybe someone had a similar problem and he could advise me something.
Regards and I'm sorry for my English.
Volvo 850, 1995, ECC damper motor problems
- Been thanked: 4064 times
Dzien Dobry!!
If the motors test out, then probably the control unit is causing a problem
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
When I looked up the meaning of the 231 and 233 codes I saw that they both have to do with the position sensor inside the damper motor. In my experience this means the dampers need to be opened up and the carbon resistance tracks inside cleaned off. They get covered with grease and stop working after a while.
231 Ventilation damper motor position sensor open circuit or shorted to 12 volts
233 Floor/defrost damper motor position sensor open circuit or shorted to 12 volts
- Has thanked: 2197 times
- Been thanked: 1850 times
Check the actual flaps are moving. I had an 850 where the flaps had melted to the internals of the air box and it would not turn. Also check the sleeves at the ends of the flap arms are not cracked. That is a common issue. You can often fix the slit using a small clamp or sometimes a zip-tie.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
I wrote up my experience a few years back, of diagnosing my system. Search for it under my name.Flow wrote: 07 Oct 2017, 10:34 Flaps, shafts e.t.c everything is ok, i can easily turn them by hand when i unscrew the motors.
M1 10W-30 HM
M1 10W-30 HM
Check the ends of the shafts where the motors sit into are not cracked. Have you calibrated the motors to ensure they are in the correct positions for open and close?
If the motors move normally when removed from the flaps when the ECC position is changed then the ECC unit is good. Check when you re-fit the motors they are at rest in the correct position for open/close when activated.
- 14 Replies
- 5646 Views
- 1178 Views
Last post by sleddriver
- 4096 Views
Last post by jvl
- 573 Views
Last post by Mrgraham
- 11 Replies
- 1502 Views
Last post by clarkr
