Hi, I was away on a journey when my 850 stopped. First lost power and ran rough for a few moments then stopped and would not start again.
Roadside assistance found that it had fuel delivery but no spark. Checked coil and said it was likely faulty.
Towed to Volvo mechanic and reports that the coil is ok but problem lies deeper. Probably ecu burned out due to possible wiring issue? Says due to the age of the vehicle that it is not worth investigating further.
Car is very sound and I recently performed major service, timing belt, water pump, pcv system etc. running nicely.
Any help would be appreciated as I don't want to scrap the vehicle.
97 model 850 stopped. No spark.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Maybe a cam/crank position sensor? (Just throwing an idea out there since it appears the majority are still asleep...)
2023 Lexus RZ450e -66k
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
+1 on above suggestion. When you check the camshaft position sensor, be sure to check the connector and wiring into the connector. Several people myself included have found that the connector crumbles with age. If it is a failed CPS, the fix is not expensive.
It might also be worth checking the distributor cap and rotor to make sure they are not worn out.
- RickHaleParker
- Been thanked: 980 times
The ECM does not control the firing on a 97. The 97 ignition system is a simple distributor system. A independent repair garage or a good shade tree mechanic could diagnose and repair it economically. 1. camshaft position sensor 2. distributor cap 3. rotor is the first three things to check.
Active
Past
Past
- Has thanked: 312 times
- Been thanked: 818 times
Next in line after those is crank sensor and the coil.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Check for spark on the centre lead going to the middle of the distributor. If the rotor button is fried (it has an internal 2.2K ohm resistor). it can immediately cut spark to the engine.
The one time my 850 wouldn't start was because of a no spark condition. Long story short I found a 20 gauge multi strand wire with cracked insulation hiding disintegrated copper inside. After I replaced the bad copper wire the car started right up. If all of the above suggestions turn out good, I'd start inspecting every inch of wire for cracks or breaks.
SouthernMan
- Year and Model: 1997
Thanks all for the replies.
I am transporting the vehicle back home (5 hours away) and will then investigate further. The workshop that looked at the car are prediicting a dead ecu because there is no response from the obd2 port at all.
Just because it is a distributor/rotor ignition system it still relies on the cam and crank sensors for ignition and these are controlled by the ecu? Yes or no?
Many thanks.
Many thanks.
- RickHaleParker
"Just because it is a distributor/rotor ignition system it still relies on the cam and crank sensors for ignition and these are controlled by the ecu? Yes or no?"
In my previous post I meant to say, the ECM does not control the firing order on a 97. The ECM does decide when to fire.
Pages 12 & 13.
https://www.volvoclub.org.uk/tech/servi ... agrams.pdf
Pages 12 & 13.
Active
Past
Past
1998v70xcbill
- Year and Model: 1998v70xc
- Been thanked: 3 times
I just had the same problem on a 1998 v70. Ended up being coil. I checked cam, crank sensor and fuel pressure. All checked out. My secondary on coil was high resistance. (my problem Coil).
check my recent post for readings on cam and crank sensor.
Bill
Bill
- 2258 Views
Last post by Sixthandredline
- 3128 Views
Last post by Roger_850T
- 3383 Views
Last post by ndphotonl
- 1971 Views
- 2714 Views
Last post by and1one1
