Did you know? 🤔
Torque specs for V70 2013 brakes
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
danexx23
Year and Model: 2013 V70
Has thanked: 0
Been thanked: 0
Great Britain
danexx23
Post by danexx23 » Sat Oct 07, 2017 6:05 am
Hi,
I am planning to change my front pads and discs in my v70 but couldn't find torque specs for the caliper bracket mounting screws.
Would there be a kind soul there to help me out with this?
Thanks
Dan
danexx23
Has thanked: 0
Been thanked: 0
Great Britain
danexx23
Re: Torque specs for V70 2013 brakes
Post by danexx23 » Sat Oct 07, 2017 1:04 pm
Anyone? There must be someone who either done similar job before, or has some info about it. Mine are 16.5 inch discs and caliper bolts are M14.
Year and Model: Lots
Has thanked: 4 times
Been thanked: 96 times
Australia
Post by precopster » Sat Oct 07, 2017 2:24 pm
Are these twin piston calipers?
If not you only need to remove the guide pins, remove the caliper cover, re-lubricate the guide pins and push the piston back. Caliper bracket removal is therefore unnecessary and to be avoided as you ideally don't want to be removing bolts with factory thread lock.
Therefore you only need the guide pin torque specs which wouldn't be high given their size; probably about 20Nm.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
danexx23
Has thanked: 0
Been thanked: 0
Great Britain
danexx23
Post by danexx23 » Sun Oct 08, 2017 12:34 pm
I actually needed to remove caliper with holding bracket as was also replacing discs.
Caliper to hub bolts are 200Nm.
Guide pins are 28Nm
Confirmed by Haynes manual and Vida.
Thanks,
Daniel
Australia
Post by precopster » Mon Oct 09, 2017 5:23 am
Reread your post. You DID say pads and Discs. Got to get out of the habit of answering posts at 4am. Glad you found the info.
