Just went through issue with a/c - pulled Climate Control Module (put original back in), replaced fan and regulator. A/C works now.
Now the dash messenger says SRS Service Required Urgent. Guessing this is an effect of having the battery negative disconnected for 3 weeks. Question is what is my next step? Would like to make sure the SRS is okay and get rid of the message.
message SRS Service Required Urgent
SandCastle
- Year and Model: 2001 v70 t5
precopster
- Year and Model: Lots
- Been thanked: 128 times
Your airbag system is now non operative.
Usually this happens when you swap out the CCM with battery connected.
You'll need a Vida/Dice or a scanner that can handle this. Also Autel MD-801 or similar.......
Cookie-the-Swede
- Year and Model: 2003 S60 2.5T AWD
- Has thanked: 1 time
- Been thanked: 4 times
NON-Operative?! Is it really? If that's the case, half of everyone driving around in a P2 volvo is driving with no airbags system. Lots of owners have that same warning displayed on their dash.precopster wrote: 07 Oct 2017, 17:35 Your airbag system is now non operative.
- Has thanked: 1611 times
- Been thanked: 4072 times
I think thats why Volvo puts the word 'URGENT' in the message.
precopster
The SRS module will NOT fire any airbags until all systems are operative. I believe this also includes any pyrotechnics for seat belt tensioning systems in the event of a collision.
You can check this on any Volvo forum or with any Volvo workshop.
It's your life........protect it or buy a Toyota.
Cookie-the-Swede
I beg to differ. It seems that the system is NOT actually disabled due to the warning light.
http://forums.swedespeed.com/showthread ... ing+urgent
Cookie-the-Swede
You might be wrong about that...precopster wrote: 12 Oct 2017, 05:48 The SRS module will NOT fire any airbags until all systems are operative. I believe this also includes any pyrotechnics for seat belt tensioning systems in the event of a collision.
IM calling those threads inconclusive. There is a VIDA reference that perhaps someone could post to guide.
Bottom line, if airbags are important to you , fix your car until the message is gone
Cookie-the-Swede
If the "urgent airbag warning" light means that the airbags are indeed disabled, then everyone driving around with it on are playing Russian roulette. I have seen this warning light on in many Volvos that I have seen.
Most often unplugging and replugging in a seat connector or stereo lead will trigger the warning. It remembers, even if you replug the connections in question and never shuts off. The dealer must reset it.
So I would say that 95% of those "airbag warning urgent" messages are bunk and the system is still operational.
If someone has source code for the SRS system we could have a good discussion about this.
When I get SRS codes on my cars, I fix them. I do have an intermittant one on my VW that I am trying to source parts, but that car rarely drives above the air bag trigger speed any how.
