1995 855 Gas Cap replacement
lcc014
Year and Model: 855, 1995
Has thanked: 2 times
Been thanked: 11 times
Post by lcc014 »
I am going to replace my 1995 855 non-turbo gas cap. I just get one from dealer but it is different - a plastic/rubber "string" attached to the cap. My original has no "string" attached and has a plastic "hook" in the bottom of the cap. New one has no "hook" at all. Where should I tide the "string" within the gas cap compartment ?
Thanks,
Ching-Ho Cheng
gmh
Year and Model: 2016 XC60 T5
Has thanked: 28 times
Been thanked: 22 times
Post by gmh »
It is usually tethered to the fuel door on the later models. Find a place to attach with a zip tie.
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I bought one of those newer style caps too. I used the upper door hinge screw to attach the tether.
Later on, I found an original hook-style cap in great condition at the junkyard, so I removed the newer style cap and tether and switched back to the old style.
lcc014
Post by lcc014 »
Thank you for the suggestion :)
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
On my V70, the cap attachs to the lid hinge pin. Then I hang the cap on the "tooth" on the lid.
Has thanked: 2200 times
Been thanked: 1852 times
Are the lid screws long enough for the mounting point to be fitted under one? Might make the lid a bit wonky though.
Neil
jreed
Post by jreed »
I was worried about that too. When I tried it on the upper hinge screw, it fit fine.
lcc014
Post by lcc014 »
I tried to use lid mounting screw and it was not long enough because the eyelet of plastic string is fairly thick. :(
