NEED a little help here from the experts!
Ive got a 2003 S80 T6 that I'm currently working on and am having trouble with some diagnosis of a problem. Ive got three OBD codes showing up that I am chasing and don't want to be a parts slinger! Ive got P0573 (should be the brake switch on the MC), P0447, and P2400. More than likely the 0447 is the one causing the code for the 2400 but I'm getting a bunch of conflicting information about what causes this code and more importantly what the fix could be? any help pointing me in the right direction is much appreciated, thank you guys and gals!
precopster
- Year and Model: Lots
- Been thanked: 128 times
Do you mean the brake pedal position sensor on the vacuum booster? If it's this you're talking about they fail very often.
precopster
P0447 can be a bad evaporative vent valve which is located on the fan shroud. It has a 2 pin connector and 2 x 6mm ID hoses connected. Check the connector by reconnecting multiple times to scrape off corrosion or dirt. Also make sure the pins are clean. Can also be a bad rear O2 sensor or a bad cat converter.
- RickHaleParker
- Been thanked: 979 times
P0447 and P2400 are both open circuit codes in the Evaporative Emission Control System. The first thing I would look for is loose or corroded connections.
Active
Past
Past
Are you referring to this valve cause it has three hoses or there is another farther down attached to the shrowd but has no electrical connector just hoses... also how likely that something has come loose at the charcoal canister in the rear? It seems pretty well protected
zjevik
- Year and Model: S60 2006
- Has thanked: 1 time
That sounds like an air leak. When I changed my brake booster I didn't change the brake booster pedal sensor and reused the old one. Soon after that I found out I still have an air leak and finally found out that the seal around the brake booster pedal sensor hardened.
See, if this is not your case by pulling or moving the pedal sensor when the engine is running.
- 2361 Views
Last post by Bob 88
- 1540 Views
Last post by IslandV70
- 21 Replies
- 3113 Views
Last post by j-dawg
- 1018 Views
- 786 Views
Last post by clifford06
