1998 s70 turbo oil supply location Topic is solved
kjj
Year and Model: 95 850, 98 S70 T5*
Post by kjj »
Does anyone have a picture clearly showing where this pipe connects to the block?
I took mine apart a few years ago to fix bent valves after losing my timing belt, and now I can't remember where everything goes. I thought I had found it by feeling around, but the hole I found is too small. The data CD doesn't show it at all, just the pipe floating in midair. By searching around I found this picture and this picture, but neither one looks like my car.
Has anyone replaced this pipe with braided hose and AN fittings? I wonder if it is too close to the exhaust.
Also, what is a good place to rig up an oil pressure sender for a gauge? I don't want to delete the idiot light switch.
Yes, I said years. :( I ran into some delays, but I've been making good progress getting it back together over the last few weekends.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Those pictures are from a '99+ style oil cooler.
I haven't dealt with the turbo oil supply line, so I don't remember exactly how mine is, but this picture appears to be a '98 and older style engine and I'm pretty sure that hose that runs to the right side of the block is the one you're looking for.
kjj
Post by kjj »
Thank you! That is way lower than I remember it being, and nowhere near where I was looking. Well, probably like 6 inches away from where I was looking... I'll check it out.
(Holy crap that engine is clean. How'd they do that?)
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Probably some sort of blasting media and/or solvent.
bmdubya1198
That came from Turbobricks, the high performance guys are serious about looks too!
