After clutch job (relevance?) I had a very slight hunting - after 100 miles CEL.
I read off P0106, MAP SENSOR ERROR and ...
found that dropping the engine had pulled the vacuum hose off the MAP sensor above the radiator fan, just under the plastic grill piece. Picture to follow
Reattach and problem cleared, confirm in 100 miles running.
2005 V70NAM56 P0106 ECM104A MAP SENSOR
Looking back at the transmission removal procedure
No mention of removing the MAP vacuum hose - this DOES need to be done or it will pull off when the engine is dropped.
CEL cleared after 50 miles of driving
- 3024 Views
Last post by InsanitySpark
- 14 Replies
- 5851 Views
Last post by V70r carbon
- 3233 Views
Last post by BlackBart
- 49 Replies
- 9350 Views
- 35 Replies
- 16993 Views
