Hello everyone,
my car has a issue with the retractor or something (according to the mechanics at a shop where I dropped my car off recently), so I cannot pull the seat belt all the way out and now it is stuck, i.e. it cannot roll back to its original position. I am a college student and the mechanics says he has to replace the whole thing, which will cost around 500 dollars and I cannot afford it. Would it be possible if I can take the seatbelt part from the passenger's side and put it on the driver side? Thank you everyone for reading my post. I appreciate it it.
Best,
Hugh N
Driver Seatbelt Stuck
hugh..you can get a cheap one from a junkyard for a lot less.
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Tasca has two different part numbers for left vs. right, so I guess you won't be able to short-change your passenger.
They list it new for $213. Be sure to check your chassis number as there is a superseded part number.
You may also give Erie Vo-Vo a try for genuine used parts
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- 555 Views
Last post by adrianleon0912
- 1024 Views
Last post by matthew1
- 271 Views
Last post by volvolugnut
- 646 Views
Last post by basilhenriques
- 1525 Views
Last post by osman
