1995 850 cooling fan not working
I have a 1995 850 and the cooling only works with the ac running. I have changed the temperature sensor, the fan relay, and the fan (low speed would not run even when directly jumped to hot wire). Any ideas?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Sounds like a bad fan motor if jumping the power directly to it doesn't work.
Try jumping both ground and +12 to it just to double check. If it doesn't run then, I'd be willing to bet it has finally died.
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
My fan did this. I changed the temp. Sensor, the thermostat. And finally I found a good relay at the JY. At first it was stubborn. I knocked it a few times with a mallot....Walla!
- 3630 Views
Last post by s10lowrider1994
- 4137 Views
- 981 Views
Last post by shiloh51933
- 1915 Views
Last post by redrayl
- 2778 Views
Last post by OnTrack
