It turns out that the front end squeal was indeed coming from the timing belt assembly. It was the idle pulley. The poor thing had seized solid and was spinning no more
So, when all was said and done I replaced the timing belt, the idler pulley, and the tensor pulley.
The car now runs great. Better than it has in a while
The actual task of changing the timing belt was easy enough. But if you need instructions a really good set can be found here: http://www.volvoclub.org.uk/faq/EngineS ... BeltChange However, these are the things that popped out to me:
* Remove the radiator fan. It makes life easier... three torx screws across the top, one set of wires and it lifts right out.
* A pipe wrench is a wonderful thing to move the drive belt tensor. A bit odd, yes... but it works very well.
* The timing marks on the cams are self-evident. They line up with notches in the upper plastic guard - about 45 degrees in-board.
* The marks on the crank are, well, stupidly hard to see in my opinion. Remove the drive belt and you will see the mark on the engine block. The matching mark on the crank gear looks, at first glance, like a chip missing from the back of the gear. This chip would be on the raised part of the tooth. The chip and the block mark should line up when the cams are lined up. Once this happens, everything becomes clear. Before that you wonder a bit...
* Once you remove the tensor piston the belt can be slipped past the drive belt pulley and the engine block. So there is no need to remove the drive belt pulley from the crank.
* Removing the tensor piston is do-able only with an ignition wrench. The lower mounting bolt is slightly behind the drive belt pulley - no way to get a ratchet in there, much less a torque wrench. Now, the torque specs for these bolts are 18 - 20 lb., which isn't much, so guess.
* I found some argument over replacing the tensor piston. Mine in excellent shape, so I saved myself the $100+ and put it back. However, I can see the argument for replacing it. If that thing goes the whole engine goes with it. Like I said, mine was good, so I simply made a note to check it every so often... but, use your judgement here. But, if it is weak - the silly thing is quite strong - leaking, or that nagging voice in your head say replace it, then replace it. It'll beat a blown engine.
* For the rest of the bolts I used 20 lb. of torque. The exact specs are hard to find, and seem to conflict, but all seem to call for 18-22 lb. or thereabouts.
Other than those points there isn't much to know. The whole task took about 3 hours from start to finish. So, if you are staring a 960 timing belt change in the face, don't fret - there was nothing difficult about it at all.
Thanks everyone for all the advice!
-Ken
