2005 V70NAM56 slight miss (early warning of 30769225 Pump Electronic Module (PEM) failure) Topic is solved
Has thanked: 1609 times
Been thanked: 4063 times
On my way out of town I notice my P2 is stumbling a bit between 40-55 mph. I feel distinct intermittant miss
Plugs and coils new, about 5k
I read ecm130A and ecm140A which are MAF and MAP sensor errors pending but not stored.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Proper OEM Denso coils?
Yes, could not cheap out on this one. Too nice. Still getting 31 mpg in town
I'll chase it down this weekend. Intermittent miss is almost certainly electrical something
Well, I though I replaced coils but one is dated 2008 and the rest are new
Wtf was my head when I did thAt job?
Update.. test drive this morning and not a single skip miss stumble. I had wiggled coil connectors last night, nothing loose. Not definitive but leaning to a coil or connector issue
JRL
Post by JRL »
Ruining my car again are we?
Our temps dropped down to 50 which I think cleared this up.
I'll replace the last coil and drive it hard
Forgot to close up on this thread. I did replace the coil but the miss never returned, so I was left with that unsatisfied feeling Matt has when he goes to shift gears, and its in D
4 months later I got a no start due to a failed PEM, which almost certainly was the cause of this misfire.
Thread here
viewtopic.php?f=9&t=84169
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
PEM?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
E Showell
Post by E Showell »
Pointy Egghead Mistake?
'95 855 auto (sold)
Pump electronic module. On P2 cars, the fuel pump relay is bonded into the Central Electrinics module , the ECM controls the fuel pump by sending a control signal to the PEM, WHICH SENDS A PULSE MODULATED signal to the fuel pump. The upside is the pump I still only run on demand so it lasts longer.part numbers 8634953 30769225
