2000 C70 window stuck
xerxes66
Year and Model: 2000 C70
Post by xerxes66 »
I bought the car with the passenger window kept up with a wood "chock" on the inside pushed down between the window and the door metal. I removed the panel and found a broken steel cable in the bottom of the door.
What tests should I run to see if the problem is just in the broken cable, the regulator, or the motor?
Thanks very much for any suggestions!
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Well, if you push the window button and hear the motor, then the motor is good. In that case, just replace the regulator without the motor. Either way, you need a new regulator.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I have replaced the cable in my friend's '01 C70...it's a common issue and a real pain. The only person I found that has the kit without paying an arm and a leg is a guy from Poland selling them on eBay. If I could recall where I got this I would post a link but it's been several years. A piece of wood "chock" was also her temporary solution until we bought the kit.
Has thanked: 2200 times
Been thanked: 1852 times
This is a common issue with the C70 as Made in Japan says. Hopefully you can find a kit of some sort or a good used 'cassette' for the window mechanism, as the only other choice is a new one at around $1000 if I recall. Hardest part is getting the window mechanism aligned from what I have read, so good luck!
