Hi all
I have a 1988 240 wagon with a 5 speed. My car has developed a pretty bad misfire when I accelerate from a stop in 1st and second gear. It only seems to be after the car is warm. It runs good when the engine is cool for the first 10-15 minutes.
Things I've done recently to try and fix the problem:
Tune up(cap, rotor, plugs)
Clean throttle body and MAF
Replaced flame trap(car seemed to run better for a short time after I did this)
Replaced fuel filter and pre-pump screen(both pumps checked out ok)
checked for vacuum leaks
checked fuel pressure regulator
One issue I'm having: In trying to adjust the throttle position sensor, I notice the it clicks only when the throttle is closing, not when opening.
Any help is greatly appreciated
Misfire/Cutting Out under Acceleration?
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Volvo Bentley Repair Service Manual (240 244 242 245) Bentley L293Roger M wrote: 01 Nov 2017, 11:32...1988 240 wagon...bad misfire when I accelerate from a stop in 1st and second gear...runs good when the engine is cool for the first 10-15 minutes.
When I get a fuel injected vehicle, I replace the injectors' O-Rings, and on redblock Volvos, I renew the intake gasket also.
How?
TerrDawg
- Year and Model: 97' V90/98' S90
- Has thanked: 7 times
- Been thanked: 13 times
I've noticed similar issues when I had a bad ground, it didn't make sense at first but the electronics need a good ground, so I found a new alternator at the junk yard since I'm on a budget .. Hope to put it on today, it'll beat switching out the batteries...
07' XC 70 Black/Lowered 136k mi
98' S90 blue 245k mi
98' S90 white super clean ! 274k mi
- 941 Views
Last post by Hardtofool
- 2378 Views
Last post by sleddriver
- 3292 Views
Last post by rguzz
- 11 Replies
- 4218 Views
Last post by bubbeck
- 12 Replies
- 2896 Views
Last post by ferocity02
