Hey, I’m new here and I’m in bad need of some advice or answers but I have a 2005 Xc70 and when I turn on my heat only the passenger side blows heat while the driver side blows cool/cold air and I have both Temperature dials on high heat I googled this issue and this forum popped up and I read a post about a guy with the exact same issue but he had a 2000 S70 so the replies he got from ppl here didn’t quite help me because of the 2 different vehicles so if anyone could please shed some light and knowledge on this issue I would much appreciate it. Thanks
Tone. P.S. sorry about the lack of punctuation
Driver side blows cool while Passenger side blows heat
Smar1991
- Year and Model: 1993 940
- Has thanked: 1 time
Could be a bad servo motor (leading to the vents not directed heat properly). Alternatively, the plastic piece that the servo shaft drive fits into cracks so the motor turns but the shaft doesn't. Not sure if the passenger servo is reachable on your model without taking apart the whole dash...
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
We have seen a few with this exact issue, sadly I don't remember anyone coming back with an update once fixed. If you do so, please let us know what it was.
Had similar problem.
When I replaced the heater core I accidentally knocked one of the levers connected to the temperature control servo motor off and did not snap it back on properly. They are right above the drivers right foot next to where the pipes go into the core.
If heater core was replaced, suggest you make sure they are properly connected.
I thought it was broken so I bought a replacement motor and levers off e-bay then realized it was not broken, just was not snapped on properly.
If you can reach up and move the lever making the heat go from hot to cold, you may have same problem.
If not, probably servo motor. They are cheap on ebay but you need to get the numbers of yours to match it up.
- 16 Replies
- 4765 Views
Last post by coded9
- 1327 Views
- 18 Replies
- 8225 Views
Last post by packetfire
- 2865 Views
Last post by regent
- 36 Replies
- 2826 Views
Last post by erikv11
