Hello,
I have a 2004 xc90 2.5T
The sunroof, map lights ,are not working.
I am getting the following codes :
uem-0038 general courtesy lighting
uem-0080 rain sensor
uem-003A extended X supply
(EXT_X)
I have tried several reset procedures,disconnect battery terminals ,touch together among at least 2 or 3 more,nothing has worked.
I am mainly trying to find out what is the extended x supply,I have searched a lot but haven't nailed it down.
I should also add that I have had the windshield replaced and also, I replaced the siren module.That code is now gone.
Any help would be appreciated.
Thanks,
Steve
Help with code UEM-003A
precopster
- Year and Model: Lots
- Been thanked: 128 times
The UEM and remote from another vehicle can be sourced and they will be paired and work just fine.
The only thing you'll need to do is carefully dig out the glass transponder off your old remote and transfer this to the new remote shell. For this purpose it's probably best to use a new aftermarket casing which you can glue back together using the old transponder chip. These transponders are in the shape of a glass capsule and are separate from the remote circuit board.
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Diagnostic trouble code (DTC) information UEM-003A:
Condition
The upper electronic module (UEM) supplies power to a number of functions in the car via Extended X-supply (EXT_X). These functions include the sun roof logic, mirror lamps in the sun visor, rain sensor, buttons for the headlining lighting and certain button lighting. Diagnostic trouble code (DTC) UEM-003A is stored if the upper electronic module (UEM) registers too low a level for power supply Extended X-supply (EXT_X). Diagnostic trouble code (DTC) UEM-003A can be diagnosed in ignition positions I or II.
Substitute value
Sun roof, mirror lamps in the sun visor, buttons for the headlining lighting and certain button lighting are switched off.
Possible source
The power supply to the sun roof, mirror lamps in the sun visor, rain sensor, buttons for the headlining lighting and certain button lighting functions is short-circuited to ground.
Fault symptom
The power sun roof does not operate
The interior lighting does not operate
No rain sensor function
Troubleshooting
Signal too low, checking for a short-circuit
-Ignition off.
If all the functions that are supplied with power from the upper electronic module (UEM) via Extended X-supply (EXT_X) are not working (i.e. sun roof logic, mirror lamps in the sun visor, rain sensor or interior lighting), it can be assumed that either the cable between the upper electronic module (UEM) and the junction point 53/505 is short-circuited to ground or the wiring from the junction point to each component is short-circuited to ground.
First check the power supply cable between the upper electronic module (UEM) and each component. If the cable is short-circuited to ground, 0 Ω will be measured.
For mirror lamps in the sun visor, check the cable between the mirror lamp connector terminal #1 and the connector for the upper electronic module (UEM) terminal #A8. Check for a short-circuit to ground.
For sun roof and interior lighting, take readings on the cable between the connector for roof lamps terminal #A2 (and the sun roof module) and the connector for the upper electronic module (UEM) #A8. Check for a short-circuit to ground.
For rain sensor, take readings on the cable between the rain sensor connector terminal #A3 and the connector for the upper electronic module (UEM) terminal #A8. Check for a short-circuit to ground.
Note! Also check that the cable to the rain sensor is not trapped under the foot of the rear view mirror. The cable can become detached from connector 54/16 and examined separately.
If all the readings result in a short-circuit to ground, it can be assumed that the fault is between the upper electronic module (UEM) #A8 and junction point 53/505.
Remedy as necessary.
Wiring diagram may be found here- http://www.volvowiringdiagrams.com/
Good luck !
Condition
Substitute value
Possible source
Fault symptom
Troubleshooting
-Ignition off.
Good luck !
precopster
When the windscreen guy did his thing what's the bet he trapped a wire under the UEM if/when he removed it for access to the seal.
- 1033 Views
Last post by thr3shold
- 7532 Views
Last post by Ldordai
- 11 Replies
- 4600 Views
Last post by RickHaleParker
- 2703 Views
Last post by jonesg
- 1375 Views
