Did you know? 🤔
Removing intake manifold 2012 xc70
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
headrc
Year and Model: 1998 v70xc
Has thanked: 3 times
Been thanked: 0
headrc
Post by headrc » Mon Nov 13, 2017 10:22 am
I need to remove the intake manifold on my 2012 Volvo XC70 to replace the alternator. Is there a tutorial somewhere on this? Thanks, RH
jimmy57
Has thanked: 2 times
Been thanked: 154 times
jimmy57
Re: Removing intake manifold 2012 XC70
Post by jimmy57 » Mon Nov 13, 2017 3:10 pm
The injectors are in the head so no gasoline lines need to be touched. Disconnect the throttle to air cleaner pipe at both ends and set aside. Remove the 7 bolts intake to head and there are two bolts down at the bottom into oil pan side. You should be able to move it for ample clearance now. You may have to cut a cable tie and unclip some wiring harness for more freedom. The intake gaskets are effectively rubber bands in grooves in intake and are re-useable unless the engine has run really hot. They are green and might stick to head and have to put back into place in intake. Check that the bolt in the drive cog is tight as those can come loose, especially if the alternator cog has an issue with its one way clutch.
