Hi All
I am getting the Brake Failure message coming up - the sensors are all reading incorrectly at the same time - this is obviously an electrical malfunction - I had the ignition problems which was fixed by the mechanic - he now thinks this is causing the error message and wants to source a new ignition system to repair the problem - I don't have the network codes
Any ideas? Where can I source a complete ignition from?
Regards
Mark
Constant Brake Failure message
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Not sure it's a good idea to start replacing parts because the mechanic 'thinks'.
The message can come from various areas, for example there is a brake relay on the CEM that can go bad. Just an example. Perhaps google up and scroll through the many available topics on such issue and try to check each thing, before replacing it.
- 987 Views
- 1470 Views
Last post by T64me
- 1000 Views
Last post by mecheng
- 2119 Views
Last post by BrickBetty
- 914 Views
Last post by [email protected]
