IPD sale Volvo Parts
Climate Control Module Troubleshooting
1996 - 2004 S40
1996 - 2004 V40
broadusc
Year and Model: 2000 V40
United States of America
Post by broadusc » Mon Nov 13, 2017 11:06 pm
I've looked at the other threads here, but don't see a solution. My climate control module has gotten more dodgy as time has gone on since I bought the car a few months back and now can go a day without working at all, which isn't great in the winter. When I first bought the car, I replaced the blower motor transistor, and things worked through the summer. Now the AC and Recirculate buttons flash when I start the car and the blower motor is very inconsistent whether it works or not. I bought a used climate control module on eBay, and I'm getting the same exact results now that I've installed it. What else can I do to troubleshoot this? Although not impossible, I'm assuming that two climate control modules are unlikely to have the same problem and it must be something else.
alschnertz
Year and Model: 1995 854T
Been thanked: 6 times
Re: Climate Control Module Troubleshooting
Post by alschnertz » Wed Nov 15, 2017 4:13 am
Tough to find good testing information on these. I've tried as well, but it sounds like yours is even worse than mine.
Xemodex has repair services listed on their website. About $350.
https://xemodex.com/us/product/climate- ... 244-10-20/
'84 Prelude
'06 MPV
'13 Ford Focus SE
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 2 times
Post by Klausc » Thu Nov 30, 2017 10:47 am
The blinking lights indicate a problem has been detected. You need a scan tool to get the codes and determine a solution. The blower should always work in 'manual' mode, but check it to determine if it runs slow or fast only. The blinking lights can also be caused by a dirty cabin temp sensor.
Klaus
broadusc
Post by broadusc » Wed Dec 06, 2017 9:48 pm
The "manual" mode is either on or off. If the unit is working, I can set it to any fan speed. If it's not, it's just dead. The fan control does nothing. I've hooked up my code scanner, but it's not throwing any code. I've cleaned the cabin temp sensor on both and both had a little dust bunny on them. Since my original post, I have to say that the "new" used climate control module is more consistent than the original one that came with the car. It usually works after it's been sitting overnight (thankfully), but if you shut it off to run in the store, it won't work when you come back out and start it up again, and then may not work until the next time it sits for a while. If you put in on auto, it's pretty much the same behavior.
Klausc
Post by Klausc » Thu Dec 07, 2017 8:49 am
A generic scan tool will not work, you need VIDA/DICE or a Volvo scan tool that can check Volvo specific codes. One that also can be used for SRS, ABS, and CEM codes. Not cheap, unless it is PC based and you have a spare laptop.
Klaus
broadusc
Post by broadusc » Wed Dec 27, 2017 6:33 pm
Ultimately, this turned out to be a bad blower motor. It finally went 100% kaput, so I had a local shop scan it to be sure and it was throwing the bad blower motor code. I swapped it out and it works like a champ now.
muammerakdas
Year and Model: 2003 s40
Turkey
Post by muammerakdas » Fri Mar 16, 2018 5:20 pm
klima fanı sorunu .sökülecek çok ucuz 2 adet ( 5k trimpot) u değiştireceksiniz.komple modülü değiştirmeye gerek yok.volvo 2003 1.6 modül
QUARKS40
Year and Model: 2010 XC60
Post by QUARKS40 » Sun Mar 18, 2018 9:33 pm
the pots are set to what value?
2010 XC60 - P*, 3 Spoke steering wheel retro, Gearshift retro.
2001 S40 - 14T, BBTB, turbo back stainless DP, Upsolute, KW, 15mm rear sway, 17" Konig wheels, Custom Arctic Silver/Sonic Blue pearl paint, custom interior
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 144 times
Been thanked: 437 times
Trinidad & Tobago
Post by abscate » Mon Apr 30, 2018 3:35 am
Salam muammerakdas,
Nerede ayarladin ( trimpots)?
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
Who is online
Users browsing this forum: No registered users and 10 guests
