I have recently experienced a problem with the Auto Transmission shifter being locked in one position.
Initially, I was going down a long steep grade so went sideways to "Manual" to shift down for engine braking, however, nothing happened, it stayed in "Drive" No problem, good brakes.
The next issue was when I parked. I couldn't shift out of "Drive" to "Park" until I manually released the lock via the lift up flap and key insert.
It seems as though I need to get the console off to see what is going on. Any thoughts on how to do this? Any assistance would be appreciated.
C30 Transmission shifter
- Has thanked: 17 times
- Been thanked: 35 times
Can you list your model year, engine and transmission as well as if your car is RHD or LHD. I know nothing about cars in Australia.
I do have a copy of VIDA in a virtual machine- might be able to look some things up for you. My first thoughts are it's low on transmission fluid... or something like a solenoid is not engaging from the shifter.
- 8014 Views
Last post by oragex
- 4465 Views
Last post by Deltaromeopapa
- 1371 Views
- 1972 Views
Last post by mf70
- 1558 Views
Last post by Cees Klumper
