Hi all,
After petrol reserve light came on; I filled in about 15 litres of Vortex95. However in less than quarter of a mile; the car started misfiring. I drove for about 30 miles and then filled up the tank to full with Shell V-power98. However the issue didn't reaolved.
Engine checklight with following codes appeared. ECM-3503 and ECM-3513 (Misfire in Cylinder 1)
So went to local mechanic and he said engine misfire is due to ignition coils. And that I also should change spark plugs.
As Coils are expensive here I just changed plugs with Genuine Volvo spark plugs but the issue didn't resolved.
I cleared codes and now codes are showing misfire in cylinder 2. ECM-3523. Cleared codes again and still misfire in cylinder 2. Mechanic says if fuel had been an issue; misfire would be random in different cylinders.
So I am thinking of ordering coils from FCPeuro, IPDUSA etc. But what is bothering me is what if the issue is beacuse of bad fuel/gas. As it occured right after refill. How can I check whether water etc. in fuel is causing it or problem is from coils.
Thank you for your time.
Volvo C70 misfiring after refuel
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Try swapping coil #4 and coil #2. See if the problem immediately follows the coil. If so, time to replace it.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- 925 Views
Last post by pgill
- 25 Replies
- 8842 Views
Last post by DavidsVolvo
- 20 Replies
- 4235 Views
Last post by undflyer
- 33 Replies
- 7431 Views
Last post by styoung94
- 928 Views
Last post by mrscullini
