IPD sale Volvo Parts
Correct alternator voltage
Help, Advice, Owners' Discussion and DIY Tutorials on the current (third) generation Volvo V70 wagon and XC70 crossover, and second generation S80.
This is a forum for owners or prospective owners of the third generation V70, second generation S80, and its siblings built on the EUCD platform.
headrc
Year and Model: 1998 v70xc
Has thanked: 3 times
Post by headrc » Fri Nov 17, 2017 10:45 pm
I continue to attack alternator problem. I swapped the regulator and now my alternator is putting out 14.8 volts with a load on it. Is this correct or is the battery being overcharged? It is a 2012 Volvo XC70 7.3 with the 180 amp alternator.
RickHaleParker
Has thanked: 2 times
Been thanked: 204 times
United States of America
Re: Correct alternator voltage
Post by RickHaleParker » Sat Nov 18, 2017 12:27 am
14.7 is considered to be the maximum charging voltage. I would not worry about the extra 0.1V, it is most likely measurement error in the voltage meter.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
headrc
Post by headrc » Sat Nov 18, 2017 8:11 am
Ok, Thanks. My concern is I had it tested at two of the local stores ...both Advanced and Oreilly's and they both said it was bad and overcharging. But I put my volt meter on it and get 14.8 volts. We are about to take a long Thanksgiving trip and don't want end up ruining the battery.
RickHaleParker
Post by RickHaleParker » Sat Nov 18, 2017 2:32 pm
The voltage should drop as the battery charges. 14.7 is the peak charging voltage, it should not stay that high for long. If it does not come down there is something wrong. Check your volt meter against another to be sure it not your meter. Have the battery checked also.
headrc
Post by headrc » Sat Nov 18, 2017 5:34 pm
Thanks Rick. I had had the battery checked ...as well as checked it myself. It is fine. I did try another voltmeter and now I am getting 14.6 to 14.73 so I am a little more comfortable with what I have. Although this does not say a lot about having the chain parts stores tests.
Who is online
Users browsing this forum: No registered users and 8 guests
