P0101 and P0302
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 46 times
Been thanked: 18 times
Post by hu5ker555 »
2005 S80 2.5T, 180k miles
Began running rough. Had Firestone pull codes and they got P0101 which would suggest the MAF. Cleaned the MAF, no change.
Kept driving for a few days, then pulled codes myself and got P0101 and P0302. This would suggest the MAF and Cylinder #2 misfire. Replaced the spark plug and everything is fine. While doing so, noticed after removing the cover plate on the motor that there was a decent amount of oil sitting in the low spots. Looks like it may have found its way out through the oil filler cap and settled down in Cylinder #2, fouling the plug.
I've ordered a new oil cap (with new gasket I assume). Will mop up the oil, replace all the plugs, and hope it all stays dry and I have a happy Volvo again. Will let you know how this turns out.
hu5ker555
Post by hu5ker555 »
UPDATE...so I replaced the oil cap, replaced all the spark plugs, and mopped up the oil. There was almost an inch of oil sitting in hole #3 on top of the spark plug. So far so good.
