If you start getting unexplained engagement of the STC/ABS on a AWD check and verify the drive axle bolts are tight. I found the passenger's side wasn't torqued to spec. I'm unsure if it ever was as no work was performed on it during my ownership.
Special thanks to Matty Moo. If I ever require a repair/replacement of my ABS module, I know which company I'll order it from. You provided additional help that assisted in finally conquering this demon.
Thanks again,
Roy B.
PSA - 99 V70 AWD drive axles - Check and tighten Topic is solved
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
- 816 Views
Last post by sleddriver
- 1438 Views
- 15 Replies
- 4127 Views
Last post by RickHaleParker
- 16 Replies
- 2841 Views
Last post by mydamnvolvo
- 1945 Views
Last post by oragex
