How to get oil out of Spark Plug Cylinders
ir637113
Year and Model: 94 850 NA Wagon
Has thanked: 12 times
Post by ir637113 »
So I've got a decent amount of oil in some of my spark plug cylinders. Long story short, about a year ago I busted the crankcase vent hose, bootlegged in a fix, and recently realized it was leaking oil into under the spark plug cover where the hose had busted. On top of that, two of my side plug cylinder covers got pinched awhile back and have gaps
Basically, I know why there's oil there and I've fixed the problem.
But I still have oil in there. Was wondering if anyone had any tricks to clean them out? I'm due for a time up and was told I shouldn't pull the plugs until I've gotten almost all of the oil out (if not all). Anyone have any experience here?
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
I've used a turkey baster to suck oil out of spark plug wells. I've also used small plastic pipettes to suck oil from places where the turkey baster wouldn't fit.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Simple green and compressed air.
85 GLH, 367 whp
00 Insight, 72 mpg
ir637113
Post by ir637113 »
tryingbe wrote: 27 Nov 2017, 11:53 Simple green and compressed air.
Like the all purpose liquid stuff? Just dump it in then spray with the air? I would assume I'd need to change the plugs after πŸ˜‚πŸ˜‚
Has thanked: 1610 times
Been thanked: 4068 times
I really would just take the plugs out, crank it over a few times, take a compression test, then put the plugs back in.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
It'll burn off. You'll be fine.
j-dawg
Post by j-dawg »
Less flippantly: I've done this by wrapping a rag around some sort of rod and sliding it into and out of the hole. Use a thinner section of rag for the threads. Repeat until the rag comes up clean. You can also use a wadded-up paper towel (be conservative with the acetone) and pull it up using long needle-nose pliers.
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
Cheap dollar store paper towel stuffed around plugs with a screwdriver.
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
It doesn't have to be squeaky clean. You can pull the spark plugs so long as there is less than an ounce or so of oil. The oil will go into the cyl and drain to the rings. Just give it 30 minutes or so to do so before starting the engine.
Suggestion: Do not clean out the spark plug holes with the plugs removed. You will end up shoving dirt into the cylinders.
Klaus
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I use the oil absorbtion pads from Oil Eater. Tear a little piece off and shove it in the hole.
