Missing rear intake cam seal
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
I found this on my 2001 V70 2.4T. There is no oil seal on the rear of the intake camshaft, just the plug which you removed. This is very model specific however, so it may not be the same for others.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
prwood
Post by prwood »
My concern is if there is a drain hole on the other side of the seal, you may be blocking oil from properly draining.
Cars I've owned:
Has thanked: 1610 times
Been thanked: 4068 times
No seal on my 1999. New cap does not seep oil.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
No problem leaving the seal in place, some mechanics like the double coverage. There are NO moving parts outside of the seal so no problem.
prwood
Post by prwood »
My assumption was that the engine was designed to operate without a seal in that location, and that putting one there would put it out of spec (in terms of the force required to turn the camshaft with or without the seal in place). But maybe the spec includes some latitude in that area... or maybe I'm being overly analytical. :-)
Cars I've owned:
