Project - 2002 S60 T5 - Need Advice on this Build - Engine, Stage 1+
Hey guys im new to the forum, volvos, and this is my first ever project lmao. That being said ive done full engine/ trans/ drivetrain rebuilds etc. So im somewhat experienced. NEED HELP WITH THIS BUILD. this guy has a 2002 s60 t5 automatic with 135000kms for 3k and in my mind ive already bought it. I want to get as close to 300 whp as i can and daily drive the thing, i was wondering how hard i can push this engine without having to pull out the engine (limited tools and garage space and money
) after i stage 0 it i was thinking of a full turbo back, fmic, and a solid tune... what else can i do without breaking the bank. What nightmares should i expect with this car. What parts do you guys suggest.Thnx
JRL
- Year and Model: Several
- Been thanked: 16 times
Tune, downpipe. exhaust and an FMIC will get you close to that (280-290 ish) while retaining 100% reliability as long as you don't beat it to death and keep it at a good stage 0.
(Do that first, stage 0, Google it).
Also check the transmission BEFORE you plunk down your dollars. Drive it for AT LEAST 45 minutes, (it has to get HOT).
Be aware of any weird shift flares, any clunking on the downshifts, 3rd to 2nd and 2nd to 1st gears.
Since you're not familiar with Volvos. spend the dollars for a 1 hour check out from a VOLVO mechanic, best money you can spend!
Ask to see all service history the seller has and good luck, I hope it's a good one!
Also, be aware that it's right at the mileage for a full or partial suspension rebuild.
While it's nothing complicated it could run into some serious money for parts, especially if it needs control arms and/or motor mounts.
Have the Volvo tech check the breather pressure and has it had a timing belt done (for time, 10 years or 105K miles).
I have a 2004 S60 2.5T AWD that I am currently having a replacement motor installed in it. It's a low pressure turbo set up so I am assuming it has a higher compression ratio than the 2.4T or T5. I am also installing a T16 turbo upgrade, Rica i-Loader software upgrade, and a Stage 2 Power pack: high flow down-pipe and a Mototec cat-back exhaust system. I was wondering if this configuration is one that might produce around the 300hp mark? Thank you for your time.
