2002 S60 non-turbo
Okay, the two issues aren't really related except that it may be a computer issue.
First the highbeams: When I pull the stalk back to flash the high beams, the lights just stay on and I have to flick again to get them to turn off. I'm not pulling past the detent.
Second problem: When I turn the blower fan off and then back on, the A/C comes on. If the A/C is off when I shut the car off, it stays off. However, if I rotate the knob all the way left to turn the fan off and then turn it back on, the A/C comes on.
Thanks.
2002 S60: High beams and A/C
First sounds like a flasher relay fault
The second might be normal latched AC operation , maybe a video of the exact issue would help clear that up.
Yaworski
- Year and Model: 2002 S60
- Has thanked: 5 times
- Been thanked: 3 times
Flasher relay or high beam relay? Assuming high beam relay, where's that located?
"Latched" A/C operation? I'll dig out the Super 8 camera and make a movie.The second might be normal latched AC operation , maybe a video of the exact issue would help clear that up.
- 879 Views
- 2415 Views
Last post by jh_on_the_cape
- 15 Replies
- 4481 Views
Last post by shiloh51933
- 1387 Views
Last post by chiefpontiac
- 1726 Views
Last post by bahara07
