Volvo 850R aftermarket actuator and spring preload
arturjarn1
Year and Model: 1996 850R
Has thanked: 1 time
Post by arturjarn1 »
Hello everybody
I ordered a new mambatek actuator , because old one needs to be changed. Mambatek actuator comes with 5 different springs, and has already installed a 9psi one. My turbo is TD04HL-13G and engine is 2.0(207 hp,b5204t), and factory boost is about 0.7 bar so about 10psi. The preinstalled spring is a bit weak i think and i would like to know if i could put inside the actuator the 0.8bar/11psi spring. Is it safe without any ecu tune? Should i stick to the 9psi spring ? What are your thoughts guys ?
Thank you
Artur
Has thanked: 2202 times
Been thanked: 1852 times
Standard TCV is supposedly good for upto 12psi, but gets a little stressed over there and can flutter of 12psi.
Don't see 10 psi and 1psi being too different. You may feel a little difference on the road. 850R with a 2.0 liter engine. Who knew?
arturjarn1
Has thanked: 1 time
scot850 wrote: 03 Dec 2017, 12:45 Standard TCV is supposedly good for upto 12psi, but gets a little stressed over there and can flutter of 12psi.
Thanks for your response. Volvo made 850R's with 2.0 engines due to tax laws in italy :).
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
I'm pretty sure the ECU will not let you have more boost.
85 GLH, 367 whp
00 Insight, 72 mpg
