2002 Volvo S60 with Battery Drain and Instrument Cluster Failing (DIM). Shipped Cluster off for repair but it did not fix the problem. I also have a battery drain problem and I saw the known fix several places by disabling the Siren Alarm.
Fixing the battery drain first is key. Already removed and tested fuses.
HOW DO I PERMANENTLY DISABLE THE SIREN ALARM? I found the instructions here to replace the module by removing the passenger tire, etc, but the car is 15 years old. Let's just disable the alarm.
Question: CAN I CUT A WIRE LEADING TO THE SIREN ALARM MODULE to DISABLE the CAR ALARM?
Once the battery drain problem is fixed, I can move on to the instrument panel.
Thank you
Disabling Siren Alarm to and Instrument Cluster Failure
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
See what people say about removing the fuse. I for one just unplugged the module from inside the fender (these connectors are hard to undo). If you just cut the wire to the connector make sure to properly insulate it.
- 2197 Views
Last post by Sailsman
- 252 Views
Last post by vtl
- 4961 Views
Last post by oragex
- 4446 Views
Last post by polskamafia mjl
- 988 Views
Last post by doublebug
