S70GLT Transmissions
mlanctot
- Year and Model: 1999 S80T6
Looking at 99 S70GLT. The engine needs a valve job and does not run. My question is how reliable are these transmissions. Our V70XC has 330,000 miles on the original tranny but then again I flush every few years. Thanks
- Martin_Frydenbo
- Year and Model: '94 850 2.5 10V
Hi
The auto transmissions on these arent the most reliable transmissions out there. But flushing them like you do every few years has a huge impact on the reliability. Thats what makes them survive. And offcourse only use approved oil.
In europe, Volvo doesnt specify any change intervalls on transmission oil, they only recommend every 90 000km (56 000 miles)
If you are using the car for a lot of towing, they recommend every 60 000 km (37 000 miles)
But they do break easy with a lot of towing and highway mileage.
//Martin
//Martin
Volvo Technician with access to VIDA
2014 Volvo V40 T3
2014 Volvo V70 T4
1994 Volvo 850 SE 2.5 10V NA
2014 Volvo V40 T3
2014 Volvo V70 T4
- Has thanked: 311 times
- Been thanked: 817 times
The auto transmissions on these cars are super reliable and have great longevity. If the fluid is never changed, that will reduce their and longevity. 30k miles is a good interval for fluid changes.
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
If the ATF is dark brown or stinks badly, I would pass. Normally, the 4 speed trannies are reliable so long as they aren't abused. Mobile 1 ATF is a good alternative, but expensive, as it can clean some of the solenoids and keep the tranny seals in better shape than DEXII/III/IV.
Klaus
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I believe these transmissions are very tough and can go 500,000 miles. I have seen them with more than that.
- 1674 Views
Last post by precopster
- 1387 Views
Last post by Tsquared
- 19 Replies
- 3347 Views
Last post by 850TurboTurtle
- 1671 Views
Last post by FLXC90
- 706 Views
Last post by lzy54610
