Because of the knocking and or screeching noise at the front right well area, I just replaced the struts and lower arm bushings on both front sides. I did NOT replace any ball joint. After all the work, still the same noise.
When I drive over a sewer lid or ice hole, I hear the knocking sound. Over a bump, the screeching sound as if it's a bad strut. Sometimes, both sounds are heard. I have mounted on the front right side, swing up and down as hard as I could and nothing. Normally with a bad strut, you would hear the screeching sound when pushing down on the car. Could this be the ball joint, maybe for the lower ball joint. The noise is only on the right front. The sway bar links are tight in place.
Am lost!
Thanks.
Knocking Screeching Noise At Front Right
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Remove the lower sway bar bolt and drive the car. See if the noise disappears. (You may want to wire the bottom of the link away from anything it might get tangled up in.)
It's not loose bolts on the link that cause a knocking noise - well they COULD cause it - but the main problem is that the pivot ball gets loose in the link.
- 2429 Views
Last post by Ou2mame
- 4889 Views
Last post by Legofan
- 2066 Views
Last post by MoVolvos
- 2491 Views
Last post by benpineapple
- 2497 Views
Last post by gntl2000
