Thermostat replacement
BrianV70
Year and Model: 2000 V70 XC AWD/SE
Has thanked: 7 times
Post by BrianV70 »
Howdy!
Since I am lazy and don't want to make a giant mess, is it possible to replace the thermostat on my 2000 V70 XC without draining the radiator?
Its taking a long time to warm up, and running at 1/3 temp on the highway in cold weather (20s F).
Thanks!
Has thanked: 1613 times
Been thanked: 4075 times
You will lose some coolant, maybe 500ml-1000ml, so cover up your alternator with plastic or tin foil, and replace coolant when done. Idle engine with cap off until level drops, then top up, then put cap on and take for short 5 minute run, COOL DOWN, then cap off and top off again.
BrianV70
Post by BrianV70 »
Sounds like about the same amount of mess then if I don't drain it. I think I will drain it, and replace whatever comes out with new coolant. Probably do the temperature sensor too while I'm in there.
Sound like a good plan?
The maintenance schedule for Volvo is replace coolant every 3 years I think. If its due, or overdue, its a perfect time to catch up.
LOB
Year and Model: 855 GLT 2.5T
Has thanked: 10 times
Been thanked: 16 times
Post by LOB »
Actually, according to Volvo you never have to replace coolant. It's supposed to last the entire life of the car as long as it is the Volvo OEM coolant. Albeit that's what Volvo wrote regarding autotrans fluid as well....
Anyhow, every 3 years sounds a bit exaggerated, at least if you use the Volvo coolant which is supposed to contain highly efficient anti corrosion stuff.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Never changing the coolant is a good way to stubbornly ruin your engine.
Three to five years is sensible. I'd use HOAT, not the green stuff.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2865 times
Been thanked: 1332 times
Post by matthew1 »
BrianV70 wrote: 08 Dec 2017, 14:39 Sounds like about the same amount of mess then if I don't drain it. I think I will drain it, and replace whatever comes out with new coolant. Probably do the temperature sensor too while I'm in there.
Yes. Draining coolant is to me far easier and cleaner than oil, and in this case will actually save you time and mess. Just don't break the fragile petcock valve on the bottom of the radiator.
Also -> Amazon link
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I use Prestone green in my BMWs and Volvos for 20 years, zero issues.
Draining coolant is easy via lower rad hose. No need for a complete drain for tstat job. Just drain about 1/2 gallon so the level is just below the tstat.
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
For draining, I just pull off the lower rad hose so I don't have to worry about breaking the petcock.
LOB wrote: 08 Dec 2017, 16:15 Actually, according to Volvo you never have to replace coolant. It's supposed to last the entire life of the car as long as it is the Volvo OEM coolant. Albeit that's what Volvo wrote regarding autotrans fluid as well....
I did look up in my manual and , as LOB wrote, no recommendation on replacement.
Kicking my self for all those gallons I could have sold here as ' Volvo coolant, as good as new per manufacturer '
I could have bundled it with used oil like the cable company does.
