ETM rebuilt unit issue Topic is solved
michalz
Year and Model: 2000 v70xc
Post by michalz »
Hi All!
Last days I have changed ETM in my car. I had some error codes with ETM and my mechanic was sure that it is Magneti Morelli faulty
ETM issue. So I have bought a rebuilt unit from the professional workshop. The car is running almost perfect, but after it catches a
proper temperature it has some strange idle behavior. It is hard to tell, so please find below two links which will take to YT.
The first situation is when I am going to stop before the lights and second is on the stop while I am moving the steering wheel.
I was wondering is it a case that I need to do something with car computer settings like some upgrade or set higher idle rpm's? Maybe
the ETM wasn't rebuilt correctly? Please share your thoughts.
Michal
V70XC, B5244T3, m56
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
The ECM may be relearning the ETM. Take it out and drive it for 50 - 100 km, see if it clears up.
Active
Past
michalz
Post by michalz »
Since change I have made around 300km and still the same.
ps. by mistake I have made post as solved but it isn't, can someone change it?
V70XC, B5244T3, m56
RickHaleParker
On your end you should see a red check mark, click to set topic unsolved.
You might try cleaning out the Idle Air Control valve (ICA)
Active
Past
michalz
Post by michalz »
I do not have any red mark. This model doesnt have IAC valve, it is integrated with ETM.
V70XC, B5244T3, m56
