If you have a car with VIN code 39 or 64 and are REGISTERED in the Golden, Green, Bay, Pine Tree, or Empire states...
your Volvo warranty on most everything engine is 15 years/150,000 miles!
Roll on!!
Covered items
Model Year 2006 PZEV Warranty
The PZEV warranty is the Partial Zero Emissions Vehicle warranty. What this warranty does is provides warranty coverage for 15 years or 150,000 miles, from the original in service date of the Volvo, for all of the emissions components. This warranty has been in effect since 2003 for certain states. In order for the car to qualify for the PZEV Warranty, it needs to have the specific engine code that was certified as a partial zero emissions vehicle in a certified PZEV state. These qualifying states and engine codes vary from year to year. If you purchase a PZEV Volvo and then move to a state that is not a certified PZEV state, you will no longer have the PZEV Warranty coverage.
Please see below for the engines, states, and covered components for Model Year 2006:
Engine VIN codes 39 & 64 are eligible if sold and registered in California, Massachusetts, Vermont, New York, and Maine
Covered Emissions Components:
Fuel and Ignition System:
Engine Control Module Hardware, Engine Control Module Software, Fuel Pump including Pressure Regulator, Fuel Filter, Fuel Injectors, Intake Air Temperature Sensor, Ambient Temperature Sensor, Manifold Absolute Pressure Sensor, Mass Air Flow Sensor, Electronic Throttle Module, Oxygen Sensor, Spark Plugs, Knock Sensor, Crankshaft Position Sensor, Camshaft Position Sensor, Central Electronic Module, Intake Manifold, Throttle Position Sensor, Idle Speed Control Valve, Engine Coolant Temp Sensor, Ignition Coil/Power Stage
Engine Cooling System:
Control Thermostat
Crankcase Emission Control System:
Oil Trap with Crankcase Pressure Regulator, PCV Connections, Calibrated Orifices, PTC nipple, Intake Manifold Nipple
Fresh Air Hose, Vacuum Nipple, Coolant Heated
Evaporative Emission Control System:
Carbon Canister, Purge Valve, Canister Closing Valve, Fuel Filler Cap, Fuel Tank, Fuel Tank Pressure Sensor, Leakage Detection Pump
Catalyst:
Catalytic Converter, Exhaust Manifold
Turbocharger:
Turbocharger Assembly including Wastegate, Turbo Control Valve, Charge Air Cooler
Automatic Transmission:
Transmission Control Module Hardware and Software
Continuously Variable Valve Timing:
Timing Device, Solenoid Valve
Miscellaneous items used in above systems:
Hoses, clamps, fittings, tubing, sealing gaskets or devices, pulleys, belts, fuel lines, wiring harnesses and mounting hardware and electronic controls (all models) used with the components listed above.
P2 2003- PZEV Are you still in warranty? VIN 39 64 in MA CA ME VT NY
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The PCV was included?
My catalytic converter also developed holes near the welds for it's bracket.
@ 18:32
@ 18:32
JRL
- Year and Model: Several
- Been thanked: 16 times
Says included if you have the right engine, live in one of those states and have under 150K miles.
- 624 Views
Last post by 850 LPT
- 13 Replies
- 4133 Views
- 1190 Views
Last post by Sspire0124
- 3495 Views
Last post by jimmy57
- 16 Replies
- 4194 Views
Last post by daninater
