2007 XC70 ETM module not appearing in VIDA
850Squared
- Year and Model: 2006 S60R
OK I have a weird situation here. Threw my friend's 2007 XC70 on VIDA and the ETM module does not appear in the diagnostic section. No ETS lights or messages of any kind on the dash. Car is surging...but there is MAF related codes in VIDA. Has anyone ever experienced the ETM module not appearing in VIDA?? Oh and my VIDA/DICE is the 2014D version.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
It doesn't have an ETM. It has the electric throttle with a simple motor and position sensor. The ECM runs that one as there is no microprocessor in the throttle. Unplug MAF to eliminate fluctuating signal causing the issue. The ECM will substitute a value and it will run but not with normal power with it unplugged. If the engine is no smooth running then MAF or air leaks are suspected.
850Squared
Jimmy, thanks so much for the information! Really appreciate it.
- 40 Replies
- 12017 Views
Last post by jonesg
- 6337 Views
Last post by Kiamaria
- 409 Views
Last post by RickHaleParker
- 1255 Views
Last post by ggleavitt
- 7191 Views
Last post by br0dy519
