Removing pnp switch and center nut just spins.
Danimal83
- Year and Model: 1994 850 Wagon Non-T
I am trying to remove and clean the pnp switch on my 94 850 wagon, non turbo. I have everything off except the center nut that is on the shifter shaft of the pnp. It will not back off. It just spins around the shaft not biting on anything. Does anyone have ideas on how to remove this nut?
- Year and Model: Many Volvos
- Been thanked: 76 times
Short of trying to get a small screwdriver under the nut and prying upward as you loosen the nut I don't know of anything other than to Dremel the nut off with a cutoff wheel.
Hopefully it is the nut that is stripped and not the shaft but given the shaft design that is the most likely culprit.
Good Luck.
Good Luck.
- 1073 Views
Last post by zombielinux
- 11 Replies
- 11382 Views
- 237 Views
Last post by volvolugnut
- 405 Views
Last post by itsmekirby
- 2544 Views
Last post by sparky77
