P0453 Code after replacing EVAP purge valve
BrianV70
Year and Model: 2000 V70 XC AWD/SE
Has thanked: 7 times
Post by BrianV70 »
Howdy!
A few weeks ago I replaced my evap purge valve with a new one. The P0446 code went away and has not returned. However, it has been replaced by a P0453. Other clues:
I have not replaced any vacuum hoses.
I have had occasional fueling problems - tank not venting and fuel spewing out of the filler neck. Then, can only add a trickle at a time. Both times it coincided with cold weather, and then fixed itself. (the first time, I blew out the filter on the filler neck with compressed airing it got better. Red herring?).
New gas cap.
2000 V70XC 126,000 miles.
Thanks everyone
BrianV70
Post by BrianV70 »
Bump
P0446 is "evaporative emission system vent control circuit malfunction"
and to add that the code is intermittent. Comes and goes on its own.
Has thanked: 1610 times
Been thanked: 4068 times
I recall this is a symptom of blockage in pipes near the fuel filler on a late, "bastard" P80
