Ignition Wire set
mrreilly
Year and Model: 1998 Volvo S70 GLT
Post by mrreilly »
What ignition wires should I buy for my '98 S70 GLT? Should i just go with OEM?
1998 Volvo S70 GLT Black/Tan
Approx. 173,000 3/27/2010
My major repairs:
Timing Belt, Left&Right Control Arms, Tie-rod ends, Lower Engine Mount, Engine Stabilizer Mount, IPD Sway Bar Links, Brakes , Head Gasket, PCV System, Turbo Rebuild, and more
White850Turbo
Post by White850Turbo »
OEM Bougicord is excellent. Only other one to consider is Kingsborne, but you'll have trouble fitting those into the stock wire holders.
-Sean
1998 S70 T5 (Almost Stock)
pfeener
Been thanked: 2 times
Post by pfeener »
Bougicord from FCP. They are the OEM manufacturer for Volvo. The wires you get will be exactly what came with the car right down to the stenciling on the wires. Stay away from the Bosch wires.
95autoturbo
Post by 95autoturbo »
I attest, stay with Bougicord try for some used ones on Ebay..., just bought me a set for 20bucks shipped less than 2k on them then the dude wrecked his car.
yes......It is an 850!
