unknown dashboard light
I have a 2017 Volvo XC90, from time too time there is a warning that comes on the dashboard which the manual does not have and the dealership has no clue what it means, any one know what this means? It's a white circle with black lines that look like tread marks thru it. This does not stay on very long and does not seem to leave any error code in the cars computer. Any help with this would be greatly appreciated.
- Has thanked: 2856 times
- Been thanked: 1332 times
What conditions does it appear in? Snow? Dry? Idle? Turning? Etc.
Have you tried snapping a picture of the dash with the ignition on but engine not started?
That usually turns on all " trouble lights" so maybe you can get a snap there.
When you start the car all dashboard lights illuminate. It's a way to see if any bulbs are out. Generally it's when you turn the ignition to position II.
Next time you're going somewhere, before you turn the ignition to position III (actually starts the car), leave it in II and take a photo.
The 2017 XC90 might be different, but this is the general behavior of cars.
- June
- Has thanked: 523 times
- Been thanked: 261 times
If you're car has DTSC, a light pops on every time the system is activated to alert you the stability control is at work. My S80 T6 has the same light though when it lights up while driving rarely can I feel any difference if the car is in motion. The light will also light if your tires spin on take off, like on a slippery surface to alert you the traction control is working. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Do you have the full screen instrument cluster or the bar graph fuel and temp gauges? Where is the warning light you are seeing?
I put 27K miles on 2016 and 2017 XC90 T6 models and never saw that symbol. The ones I drove all had the full screen clusters. The one in the drive now is the same and I can't use a light and cheat and try to see the warning lamps not lit on the TFI full screen type clusters. The traction control light on that style is a car icon with curving skid marks.
- RickHaleParker
- Been thanked: 978 times
Draw the symbol on a piece of paper, take a picture, upload the picture.
Active
Past
Past
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Look in the owners manual for descriptions of all the warning lights.
Current Volvos:
