IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
Vida 2014D Times out 12/31/2017 23:59 Topic is solved
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
RickHaleParker
Has thanked: 3 times
Been thanked: 354 times
United States of America
RickHaleParker
Post by RickHaleParker » Sat Dec 23, 2017 7:49 pm
Has anybody found a way to offset the date in a virtual machine? 2014D expires 12/31/2017 23:59.
I have dedicated hardware with the clock set back to 2014 and no network time and date sync.
I would like to move it to a virtual machine but I know it will time out at the end of the year.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
1997 S90, B6304S, AW30-42, Bosch Motronic 4.4 - Sold
RickHaleParker
RickHaleParker
Re: Vida 2014D Times out 12/31/2017 23:59  Topic is solved
Post by RickHaleParker » Tue Dec 26, 2017 7:30 am
Shoot ... that was easy enough, once I realized it does not matter if the virtual machine bios date changes. What matter is if Vida sees it change.
This is all done in the virtual machine not on the host.
  • Install the operating system in the virtual machine, set a password when you create the user.
    Disable network time sync.
    Create a batch file with one command "Date mm-dd-yy", where mm-dd-yy is date in the past.
    Create a Task schedule that will trigger when you log in and run the batch file.
    Reboot VM operating system to make sure the date is sticking.
If the date is sticking, Vida will see the date as a never ending day.
Now install Vida on the virtual machine.
I used Date 01-01-14, Vida 2014D installs and will never time out.
If you want, you can now set the user account for automatic login.
Still to do: Get a USB port mapped to the VM.
Has thanked: 8 times
Been thanked: 143 times
Canada
Post by scot850 » Mon Jan 01, 2018 9:57 pm
I have the same problem trying to log into my Vida 2014A and also now 2012 which is in the VM.
I am not a techie/IT guy so any help would be appreciated on how to get around this. I do not have 2014A in VM as it was working fine in MS 7 Pro for the last 3 years.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
doublebug
Year and Model: XC90 2007 D5
Has thanked: 0
Been thanked: 3 times
Belarus
doublebug
Post by doublebug » Tue Jan 02, 2018 3:16 am
solution is easy.
Patch is self extracting archive. So
Unpack patch used in previous install and find 3 files.
filldb.cmd
filldb.sql
license
Edit "license" file. It is XML and can be edited with any text editor.
there is string subscriptionExpireDate="2017-12-31 23:59:59"
Set to whatever date you want and run filldb.cmd
That is all.
These users thanked the author doublebug for the post (total 2):
RickHaleParkeroaktreerob
If you have questions about Volvo firmware ask me. I may know an answer :)
Canada
Post by scot850 » Tue Jan 02, 2018 8:20 am
Many thanks Doublebug! You are a star and your help is appreciated! I will see if I can figure this out but may need more help.
2006 XC70
Canada
Post by scot850 » Tue Jan 02, 2018 10:46 am
Found the file 'license' and changed the date. What I don't know how to do is how to run the filldb.cmb? A little compasion here for a non-computer guy please!
Thanks,
2006 XC70
RickHaleParker
RickHaleParker
Post by RickHaleParker » Tue Jan 02, 2018 11:05 am
filldb.cmd
filldb.sql
license
It not as easy as you make it sound.
If I unpack to C:\ these files and patch folder get deleted by 2014A.exe and 2014A-B-D.exe after the patch is run.
If I unpack to a different folder I can get the patch folder and the three files.
I moved the patch folder to C:\Vida and ran filldb.com from the command line. Got a cannot find specific path error.
What would be nice if somebody can make a new patch with the license file edited.
Has anybody else discovered the 2014D RePack comeing out of Russia? It runs native on Windows 7, 8 and 10 with IE11.
The Repack does not have the subscriptionExpireDate fixed in the patch.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Tue Jan 02, 2018 6:12 pm
Successfully modified the 2014A patch to extend the subscriptionExpireDate to 2099 23:59:59.
The patch will not enable you run 2014D under windows 10 with IE11. For that your need more then the patch.
Get attached file.
1. Unpack 2014A-B-D-2099.zip file to Desktop.
2. Run 2014A-B-D-2099.exe
3. Install to C:\
4. Reboot and log in to Vida after the icon turns green.
2014A-B-D-2099.zip
I have Vida 2014D running native in Windows 10 E11 in real time in a VM.
Next ... do it on the host just like any other application.
Thanks to Doublebug for showing where to look.
You do not have the required permissions to view the files attached to this post.
Last edited by RickHaleParker on Wed Jan 03, 2018 5:48 pm, edited 7 times in total.
These users thanked the author RickHaleParker for the post (total 13):
gubbsvinbumberyerikv11gmhoaktreerobRattnalleAaronsVolvosudshyperiongateCedBobKing and 3 more users
velorider
Year and Model: 2005 S60 T5
Has thanked: 1 time
Been thanked: 7 times
velorider
Post by velorider » Tue Jan 02, 2018 6:52 pm
Went to try out my Vida/DICE today for the first time and I could not log into Vida 2014D. I reset the system clock but the system detected that, with a message about the last login date is newer then the system date. So that I don't think is going to work well. I tried the sqldb update on the existing Vida VM but could not get that to work either.
Here are the steps I needed to get mine to work:
1. I reimported the VM, since nothing seems to get the old one to work.
2. Reset the host system clock to ensure it was the date/time issue.
3. Launched Vida VM and confirmed I could log in.
4. Performed the sqldb update
5. Closed the VM
6. Reset the host system clock to the correct time
7. Launched the Vida VM
8. Was able to login
I don't understand way the sqldb update on the original VM wouldn't work.
Good luck!!
RickHaleParker
RickHaleParker
Post by RickHaleParker » Tue Jan 02, 2018 7:17 pm
I got 2014D running native in Windows 10 Pro with IE11 ... no VM, no tricks with the clock.
Deleted my VM and Shutdown my remote Vida machine.
