2010 S80 Steering Wheel Air Bag Removal
dcbarryva
Year and Model: 2018 S80
Post by dcbarryva »
I want to replace the trim ring (peeling coating on the plastic is a bit sharp) on the steering wheel and first need to remove the air bag. I have tried several torx sizes (25, 27, and 30) inserted in the two holes in the real of the wheel but none seem to fit. Does anyone know if this the correct method? If yes, the correct torx size? Any further instructions would be appreciated. In advance many thanks.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
If it's the same system as in the video, it's not a torx screw, it just like a tab, a regular flat screw driver inserted then pushed somehow upwards to unclip the tab
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
It is like Oragex says. Just turn the wheel so you can get the screw driver or other tool in there - it cannot be too long - but neither too short.
