2008 x70 torque values for front end
vcowens
- Year and Model: 1998 V70, 1991 240
Hello, everybody. I've just bought a 2008 xc70 to replace my 1998 V70 with 400,000 miles on it. I need to replace all the usual front end parts. Does anyone have a list of the torque values for the 2008 xc70? I haven't had any luck finding a manual or any info online. Thanks.
Steve H
- Year and Model: 2008 S60 2.5T & XC70
- Has thanked: 6 times
- Been thanked: 10 times
Steering
Driveshaft to wheel hub (rear), 35 Nm
Driveshaft to wheel hub (front)Stage 1: 35 Nm Stage 2: 90 degree
Wheel knuckle rear to body, 180 Nm
Wheel knuckle to strut and spring assembly, 110 Nm
Subframe rear to body, 110 Nm
Ball joint to wheel knuckle, 110 Nm
Lower arm rear to wheel knuckle, 110 Nm
Lower arm rear to subframe, 90 Nm
Lower arm front to subframe (rear mounting), 175 Nm
Lower arm front to subframe (front mounting)Stage 1: 140 Nm Stage 2: 45 degree
Upper arm rear to wheel knuckle, 110 Nm
Upper arm rear to subframe, 110 Nm
Steering wheel to steering column (center screw), 48 Nm
Tie rod to subframe, 110 Nm
Tie rod to longitudinal stay, 110 Nm
Steering wheel control module to steering column, 0.9 Nm
Steering column to dashboard, 24 Nm
steering column to steering gear (steering shaft joint), 25 Nm
Track rod end to track rod, 90 Nm
Tie rod end to wheel knuckle, 80 Nm
Steering gear to subframe, 140 Nm
Pressure line to power steering pump, 30 Nm
Pressure line to steering gear, 20 Nm
SUSPENSION
Strut and spring assembly to strut and spring assembly turret, 30 Nm
Wheel to wheel hub, 140 Nm
Wheel bearing rear to wheel knuckle, 110 Nm
Rear stabilizer bar link to stabilizer bar, 15 Nm
Rear stabilizer bar link to lower stabilizer bar, 60 Nm
Front stabilizer bar link to strut and spring assembly, 60 Nm
Front stabilizer bar link to stabilizer bar, 60 Nm
Bearing rear shock absorber to body, 30 Nm
Bearing front shock absorber to shock absorber, 50 Nm
Rear shock absorber to wheel knuckle, 175 Nm
Rear shock absorber to wheel knuckle (Nivomat), 280 Nm
Pressure sensor tire, 8,5 Nm
SUSPENSION
- 646 Views
Last post by Salomons Driveway
- 2086 Views
- 2014 Views
Last post by ThaddeusTheBold
- 5341 Views
Last post by 93SCMax
- 890 Views
Last post by 454cid
