Did you know? 🤔
2008 x70 torque values for front end
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
vcowens
Year and Model: 1998 V70, 1991 240
Has thanked: 0
Been thanked: 0
United States of America
vcowens
Post by vcowens » Thu Dec 28, 2017 3:44 pm
Hello, everybody. I've just bought a 2008 xc70 to replace my 1998 V70 with 400,000 miles on it. I need to replace all the usual front end parts. Does anyone have a list of the torque values for the 2008 xc70? I haven't had any luck finding a manual or any info online. Thanks.
Steve H
Year and Model: 2008 S60 2.5T & XC70
Has thanked: 1 time
Been thanked: 5 times
Steve H
Re: 2008 x70 torque values for front end
Post by Steve H » Sat Dec 30, 2017 6:57 pm
Steering
Driveshaft to wheel hub (rear), 35 Nm
Driveshaft to wheel hub (front)Stage 1: 35 Nm Stage 2: 90 degree
Wheel knuckle rear to body, 180 Nm
Wheel knuckle to strut and spring assembly, 110 Nm
Subframe rear to body, 110 Nm
Ball joint to wheel knuckle, 110 Nm
Lower arm rear to wheel knuckle, 110 Nm
Lower arm rear to subframe, 90 Nm
Lower arm front to subframe (rear mounting), 175 Nm
Lower arm front to subframe (front mounting)Stage 1: 140 Nm Stage 2: 45 degree
Upper arm rear to wheel knuckle, 110 Nm
Upper arm rear to subframe, 110 Nm
Steering wheel to steering column (center screw), 48 Nm
Tie rod to subframe, 110 Nm
Tie rod to longitudinal stay, 110 Nm
Steering wheel control module to steering column, 0.9 Nm
Steering column to dashboard, 24 Nm
steering column to steering gear (steering shaft joint), 25 Nm
Track rod end to track rod, 90 Nm
Tie rod end to wheel knuckle, 80 Nm
Steering gear to subframe, 140 Nm
Pressure line to power steering pump, 30 Nm
Pressure line to steering gear, 20 Nm
SUSPENSION
Strut and spring assembly to strut and spring assembly turret, 30 Nm
Wheel to wheel hub, 140 Nm
Wheel bearing rear to wheel knuckle, 110 Nm
Rear stabilizer bar link to stabilizer bar, 15 Nm
Rear stabilizer bar link to lower stabilizer bar, 60 Nm
Front stabilizer bar link to strut and spring assembly, 60 Nm
Front stabilizer bar link to stabilizer bar, 60 Nm
Bearing rear shock absorber to body, 30 Nm
Bearing front shock absorber to shock absorber, 50 Nm
Rear shock absorber to wheel knuckle, 175 Nm
Rear shock absorber to wheel knuckle (Nivomat), 280 Nm
Pressure sensor tire, 8,5 Nm
