So I notice on start up while still at idle what sounds like somebody trying to squirt washer fluid about 6-10 times in what seems to be an entirely random sequence, but it happens every time I start the car.
Second thing, in today's brutal cold -- high of about +16F -- I noticed what sounded like a spray paint rattle can shaker when I spun the wheel in tight quarters maneuvering on take off. Any thoughts as to what theses various sounds could be?
Sounds from the cockpit - 2006 V 70 2.4 base
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
Based on another post by Oragex I think this is a bad brake booster check valve. (Brake booster pump switch?)
'95 855 auto (sold)
'95 855 auto (sold)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Its normal on first startup for vac pump to cycle a few times.E Showell wrote: 12 Mar 2018, 05:51 Based on another post by Oragex I think this is a bad brake booster check valve. (Brake booster pump switch?)
I'd check the steering fluid.
Have someone steer the wheel in park as you watch the pump and acc belt .
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Park on gravel or grass or lift the car before you start turning the wheels back and forth. Bad for tyres and servo to steer while standing still on a hard surface.
I've got a few spray can rattle noises from the dash on cold start as well. Been the same for two years so I've just stopped listening.
- 354 Views
Last post by Acromion1754
- 17 Replies
- 4865 Views
- 1170 Views
Last post by Scruffy
- 667 Views
Last post by jxramos
- 2124 Views
Last post by SonicAdventure
