I have a 99 S70 AWD with 100K. Here in the northeast it is very cold right now, single digits. One recent night my dash lights would not go on when I turned the switch on. After just a short time, 1-2 minutes, they came on and I drove off. On a more recent and particularly cold morning the car started and drove with heat no problem after being garaged all night. I parked it for about an hour. When I started it again, the engine came up to temp as usual but the heat blower did not come on. After the short drive home I shut it off and restarted and an d the blower cane on immediately. Tonight, I had a similar blower failure after driving with heat, shutting the car off for literally two minutes and then restarting it to have the blower not come on. Out of curiosity, I turned the switch to turn on the dash lights to find that they would not come on. I shut the car off and started it a couple times but no luck. When I got home, I shut it off and stared it again and the dash lights and the blower came on.
I suspect that it is the headlight switch based upon reading that the power for the blower goes through that switch. Is this correct ? Are these related or unrelated issues and are there other things that I should be looking for like a common relay or something? Thank you.
no dash lights and no blower
Andys_Volvo
- Year and Model: 99 S70 AWD
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
Sounds like the ignition switch to me.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Andys_Volvo
Thank you for the reply. I will check it out.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
My original ignition SW is just now beginning to act up, after 20yrs. When it does no headlights, dashlights, radio, cabin blower, etc. By just moving the key a bit, they all power up.
M1 10W-30 HM
M1 10W-30 HM
- RickHaleParker
- Been thanked: 979 times
When its acting up, take one finger and tap the bottom of the key.
Active
Past
Past
Andys_Volvo
Thanks for the input and suggestions. I will try that next time it occurs and if that takes care of it replace the ignition switch.
- RickHaleParker
We suspect the ignition switch return spring is getting weak and does not push the switch all the way to POS II. If that is the case, a little nudge will get the ignition switch back to POS II. Many just learn to live with it. My '97 S90 does it every time. By habit, I rake my Index finger up the back side of the key after starting. Sometime I forget there is a problem.Andys_Volvo wrote: 04 Jan 2018, 20:23 Thanks for the input and suggestions. I will try that next time it occurs and if that takes care of it replace the ignition switch.
Active
Past
Past
- 3515 Views
Last post by BEJinFbk
- 240 Views
Last post by 5rivers
- 46 Replies
- 12491 Views
Last post by 93Regina
- 842 Views
Last post by ovlov058R
- 1223 Views
Last post by SleeStak69
