I'm trying to get the black bulb holder back into the stop light section. No matter what I do, it is in such an awkward spot that I cannot get the holey on place to twist it and lock it in place.
Any tricks to do this?
Cannot refit stop light
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
I'm having the exact same problem with my right side blinker. It came out real easily but the lugs and electric contacts are not smoothly designed.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
It might work to hold the bulb holder with a pair of channel lock pliers if it’s not a straight shot in. Or a pair of needle nose if it IS a straight shot. That will also give you plenty of leverage to twist it but be careful not to twist it too hard.
Georgeandkira
Which tab?
"..behind" means what?
What indicator? The one in the dash board? The light itself?
Are you talking about the electric contact of the fixture itself? ...Or the wee contact tab on the removable socket?
qwertyjjj
- Year and Model: V70 2004
- Has thanked: 1 time
The metal connector at the bottom of this photo under the grey plastic is loose. I also bent, and tried to straighten, the pins going into the grey connector.Georgeandkira wrote: 05 Jan 2018, 12:23 Which tab?
Georgeandkira
I hate to say this but...since the metal contacts have been bent or damaged(?) it might be time to remove the light fixture so you can work on it precisely.
To make electrical contacts so shoddily is unforgivable. Best of luck.
In my case it's still too cold to go out and play with this junk. This week I hit it.
- 2869 Views
Last post by siboyslim
- 7071 Views
Last post by obayha
- 20 Replies
- 9278 Views
Last post by jsrnsis
- 48 Replies
- 9848 Views
Last post by E Showell
- 1963 Views
Last post by sleddriver
