PS Resevoir Flopping Around
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Been thanked: 10 times
Post by jtp »
The upper clip on the PS Resevoir where it clips into the coolant Resevoir just snapped off. There is evidence of a PS fluid leak around the Resevoir but I’m assuming that’s just from the Resevoir flopping around.
This is a new failure to me, usually I just get the common failures.
My questions are:
1) repair seems straightforward, I just replace the Resevoir and once hooked up bleed air out of the system. Am I missing anything?
2) Is this just 19 year old plastic breaking or the sign of any other issues (coolant tank getting weak and expanding or something)?
Thanks!
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
Has thanked: 1613 times
Been thanked: 4075 times
Just old plastic in cold weather. You could just wedge it in with foam or a zip tie for a simple repair
Make sure the hoses aren't fouling the serp belt. If you do replace, just tip it to burp air, I don't think there is a bleed procedure but will check
jtp
Post by jtp »
I went ahead and ordered one. It is insanely cold here in the Mideast this year so I can see how that could make it brittle.
I wish they would have kept the 850 design I’m used to. Never had an issue with those reservoirs.
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
